  1. Member coody's Avatar
    Jan 2005
    Does it mean the blu-ray DVD player can connect an external hard drive to play any HD video files or HD movies saved in that hard drive if the blu-ray DVD player has a USB port?
  2. Somethimes it is only used for firmware upgrades, but some models allow you to plug in a USB storage device and play files, it depends on the make/model.
    Even those that do play from an external device sometimes only play certain files. Some might play MKV/MP4/AVI, some might only play AVI.
    Best to read up on the machine's specs before you buy.
  3. It varies by model but at the very minimum it will play MP3's and JPEG from a key drive, some models support DivX and MKV.
    canada
    For my sony bdp s350 the usb port is used for bd live and updates,nothing else.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    It should all be explained in the player's operation manual.
    http://www.kiva.org/about
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Also note 99% of them will be limited to fat32 which means no files larger than 4gb.
  7. Member coody's Avatar
    Jan 2005
    Is it possible to connect an external hard drive to an HDTV to play the HD video directly, by the way?
    Feb 2008
    Twin Peaks
    That would depend on the TV's own functionality.
