Hi folks. I'm just looking for a way to rip my DVDs to whatever format, no matter how large the file is, that will stream to a PS3 and Xbox 360 that will be lossless. Prefer 5.1 but will deal with 2.0 if necesary. Is there any format that works for both? This seems like something simple but I haven't found a way yet. Thanks in advance.
Ripping to .MPG or .VOB will be "lossless" as you aren't converting anything, you will be using the original streams.
I'm pretty sure the PS3 can handle MPG or VOB, but the Xbox 360 can only handle it in Media Center mode, not when streamed to the dashboard.
It should be possible to set up basic media sharing to the PS3 and set up the 360 as a media center extender on the same PC. -
Interesting. I thought VOB was a couple different files if you ripped it. What program do you use to do this? Thanks.
I dont' really care what kind of files they are as long as they are lossless video (audio if possible) and work with a ps3 and xbox.
Yes to mpg but not vob. And I don't know if it will handle hd mpg - dvd mode mpg I am pretty sure it should see no problem - it handles m2ts just fine.Originally Posted by mh2360
The 360 can't handle mpg that I'm aware of though I haven't tried recently.
What it can handle natively is divx and possibly xvid (though not the more exotic variants). AND IT CAN HANDLE WMV just fine. If you encode to wmv you can stream it in anything and the 360 will see it.
What you should do is rip however you want and stream with tversity or playon (the file only local stream mode of playon is free - the integrated hulu/amazon stuff is subscription based). Than you can keep it in its original format on the pc and stream with the software doing the transcoding. Tversity works just fine with both ps3 and the 360 (I have both systems and have used tversity on both).
Lossless video is a tricky one. I can't offer suggestions on that at the moment......Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
PS3 Media Server will also serve to both the PS3 and Xbox, and happily sends mpeg-2 video, even over wireless-G networks.
Read my blog here.
Xbox 360 and PS3 format for streaming
By robotball in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2011, 14:03 -
Rip DVDs to my HD so that I can stream them to my PS3
By joegeis in forum Newbie / General discussionsReplies: 18Last Post: 11th Oct 2009, 17:47 -
Xbox 360 or PS3 as media server??
By Browncoat in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Dec 2008, 00:56 -
PS3/Xbox 360 (HD) captured to PC.
By KameronK in forum Capturing and VCRReplies: 12Last Post: 2nd Jun 2008, 22:24 -
Xbox 360/PS3 Capturing guide...
By igor_video in forum Capturing and VCRReplies: 5Last Post: 24th Jul 2007, 08:37
