Hi,
I bought a Samsung wave recently which supports mkv files albeit without subtitles (external srt files are supported) or multi-track support (it just plays the default track).
I have noticed that it displays the thumbnails instantly for some mkv files whereas for some it takes a few seconds and still displays a default video icon.
I accidentally found out that files which have something called "Cover" (from MediaInfo) display thumbnails.
I have attached an image showing the same.
My question is, what it is & how to embed it?
I am a novice w.r.t. AV tinkering but am fairly accustomed to using tools such as miniCoder, mkvMerge GUI, mkvExtract GUI.
Thank you for reading this.
In mkvmergegui I think you should add the cover image under the attachment tab, see http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#attachments . So try load your mkv, under attachment add an image, make a new mkv and see how it works.
@Baldrik
That was it. So Cover actually denotes the presence of attachments? It worked for a few files. Attaching absolutely anything worked, be it a tiny square jpg or a dummy text file.
But I think, my deduction was wrong >_<. I found two files without "cover" that were exactly the same (except the length. difference of a few mins). One displays thumbnail but the other doesn't. Maybe its a flawed mkv implementation of Samsung's part.
I have attached the file details I got from MediaInfo.
02 displays thumbnail whereas 01 doesn't.
Can you please take a look?
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 10:45 -
[Help] Blu-Ray > MKV > Hardcoded Vid & Sub > MKV > PS3
By psionicsin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2011, 02:07 -
Help -prob playing mkv w/dts&emb subs on Samsung ln40b650t1fxza LCD
By sldiri27 in forum Media Center PC / MediaCentersReplies: 1Last Post: 26th Oct 2009, 02:34 -
Help -Prob playing mkv w/dts&emb subs on Samsung ln40b650t1fxza
By sldiri27 in forum Newbie / General discussionsReplies: 0Last Post: 25th Oct 2009, 23:55 -
FairUse Wizard 2.8 & MKV Encoding with VC1 & AC3
By ozzyjunk in forum DVD RippingReplies: 0Last Post: 25th Mar 2008, 13:25
