Hi. as we all know there are hundreds of tools out there. I need to cut out about 10 to 30 seconds of 120 movies (on DVD and DivX/AVi) and I really don't have time to use full-rippers and hard tools (if you know what I'm talking about). so I really need your help about a nice and easy program which could cut/extract some seconds from movies as fast as it could.
thanks
You can also use DVDFab Passkey in the background to break encryption. It is free while still in beta.
When cutting small sections out of a dvd, I would normally use DVDShrink in ReAuthor mode, or a commercial program called VideoReDo if finer control is needed on the cut point. For avi files, AviDemux has always worked well for me.
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 12:04 -
What Is The Quickest/Easiest Way To Shrink MKV File
By Teac23 in forum Video ConversionReplies: 2Last Post: 19th Feb 2009, 03:56 -
best, easiest way to cut bad section out of vob file
By dblake2 in forum EditingReplies: 2Last Post: 16th May 2008, 17:53 -
what is the easiest software to cut an audio file?
By marlo in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2008, 13:45 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 15:16
