Never use a Video Repair software before, can someone recommend one. My Niece had this Video that freezes up about a quarter way in when played in a DVD player.Running XP service pack 3. Thanks.
VOB files, I thought of extracting the Video_TS file and repair it somehow, if it is remotelly possible.
If the disc is undamaged, VOB2MPG can extract the MPEG as one large file, then you can reauthor it. If the MPEG file itself is damaged, then you need a MPEG editor to cut out the damaged parts. AVIDemux is one.
It the disc is the problem, examine it for scratches or other physical damage. You can try using something like ISOBuster to read a damaged disc, but for scratches, polishing them out is a better idea. Discs play from the inside out, so look for any damage about 1/4 the way out.
Or quick and easy if bad authoring is the problem, run it through DVD Shrink with no compression and reburn.
Can't remember the name of video repair software
By etansonic in forum Newbie / General discussionsReplies: 3Last Post: 14th Nov 2011, 10:40 -
Video repair
By nacho_cheese in forum Video ConversionReplies: 2Last Post: 19th Apr 2010, 16:26 -
Computer Repair Shop Software
By Poppa_Meth in forum ComputerReplies: 5Last Post: 19th Jan 2010, 05:52 -
Question about how Antivirus software can repair severe virus infestation
By jimdagys in forum ComputerReplies: 3Last Post: 3rd Dec 2009, 05:59 -
NEED HELP! FREE .bkf file/archive repair software....
By Scooter_NJ in forum ComputerReplies: 2Last Post: 2nd Mar 2009, 10:00
