Hello there, I have a question for you guys. I have a ILO DVDR04 and have just had to replace the drive. Its the asme one that came out of it. Its a DDW-451S. i have the 3 hour option when I look for it. I have run the update's from gtrman from another forum. It will see and play a disk from the store with a movie on it. It will start to prepare a blank disk, it will take 3-4 minutes and then come up "invalid Disk" The disk's that I am using are DVD+RW. These are the same disk's that I used before ther drive quit. I am looking for some instructions on what I have to do here.
Any help would be GREATLY appreaceated.
Thanx in advance, Sam
What happens with a DVD+R ?
It runs thru the prepairing mode and then says invaild disk. I can play disk from the store and ones that I have recorded before, it just wont grab a new dvd to burn.
Thanx again -
The ONLY reliable RW discs (+ or -) are made by Verbatim and that is it. Forget about what worked in the past and try Verbatim and see if it's better. That is one suggestion.
I assume that this is a standalone DVD recorder. Because DVD recorders are fussy about drives and many will only work with a very small number of drives due to size or connection restrictions, this causes people to look for old drives on Ebay, etc. I can't totally rule out that you got a bad drive if you bought one from some guy on Ebay for example. For all you know someone just removed a drive that's not right and sold it to you. Or maybe they gave it a very quick test with a store bought DVD and didn't try to make a recording with it and they aren't deliberately trying to cheat you but they simply didn't fully test the drive before selling it. Many of these recorder drives are now quite ancient and at some point soon it's going to be almost impossible to find replacements for them.
Replacing a DVD+R Drive in an Ilo DVDR04, is it really that simple?
By V Bot in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Jul 2010, 09:48 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 03:12 -
ILo dvd recorder not cooperating
By jhayes in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Dec 2007, 10:06 -
Feeding ilo DVDR05 output directly to PC, is it possible?
By superspeedfreek in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Jun 2007, 12:43 -
Convert ILO DVDR04 into LiteOn 5005x!
By D'oh! in forum DVD & Blu-ray RecordersReplies: 16Last Post: 21st May 2007, 12:35
