Hi, I have a slightly older but fast PC built for use as a digital audio workstation. I am using the M audio delta 1010. Will Sony Vegas 7 pro work with this audio interface
I also tried to install the Sony Vegas on the computer but I get a message that says I cannot because I don't have the microsoft directX 9.0
my computer will not let me download it. I am running XP and I think service pack 2, will downloading this mess up my computer?
time to update to sp3, as sp2 is no longer supported or going to receive security updates. dx9 won't hurt anything.
not sure what you expect to do with the 1010, vegas is a video editor that works mostly with files not live audio.--
The place to ask is in the M-Audio forum. Here is a guy on XP trying to import a delta 1010 into Vegas.
http://forums.m-audio.com/showthread.php?20918-upgrading-rig-with-my-old-M-Audio-Delta-1010Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I have an M-audio Delta 1010LT PCI card installed in an Intel DP35DP mainboard with a Core 2 Duo E6850 processor that has WinXP SP3, 4GB system memory, Adobe Premiere Pro 2, Audition 2, and Sony Vegas 8 in it. Premiere and Vegas see the 1010LT if it's configured in Windows as the default soundcard, and both also only see 2 of the 8 inputs as configured default as well. They may or may not be able to see the other inputs depending on how things are configured, but I'm not bothered.
That's because Audition sees all of the 8 inputs, which is what I originally intended for: multi-track recording a band. So does the Ableton that came with the 1010LT. I'd never try using a video NLE to capture and/or manipulate multi-track audio, but that's just me
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Using Vegas on my digital audio workstation
By fuzzblaster in forum Software PlayingReplies: 1Last Post: 21st Sep 2010, 17:46 -
Is this the end? Mixing filetypes in Sony Vegas
By storhuvve in forum Video ConversionReplies: 8Last Post: 8th Mar 2010, 04:53 -
Mpga Audio in Vegas 9.0 doesn't work
By NarutoS212 in forum EditingReplies: 3Last Post: 24th Dec 2009, 20:47 -
DVD Audio Rip Issue (Muddled High End)
By RKelly in forum AudioReplies: 4Last Post: 28th Nov 2009, 14:38 -
Sony Vegas Capturing Outside Audio instead of MiniDV Audio
By RKelly in forum Capturing and VCRReplies: 3Last Post: 29th May 2008, 09:22
