Hi,
I'm after a low-to-mid-range 5.1 speaker system. Anyone had any experience with http://ubuyhardware.com/p~p-1961953588~b-11560000~Klipsch-HD300-51-Channel-Home-Theate...er-System.aspx ? I can't really stretch much beyond the price of that one; is there anything around the same price that's better?
Thanks in advance!
No experience with that particular setup, but Klipsch has been a good name with audiophiles. It's probably more suitable to a small room as the sub appears to be a 6.5" one. The stereo and surrounds are about 6" X 4" X 4" cabinet size, so don't expect big sound. It doesn't come with speaker cables, but a trip to a hardware store for some zip cable is no big deal.
One of our members may be more familiar with the speakers.
And welcome to our forums.
Try this review:http://www.soundandvisionmag.com/tests-reviews/speakers/2009/09/klipsch-hd-theater-300
S&VM is pretty reputable, and the review sounds quite informed and objective.
Bottom line, not too bad for the price as long as you don't try to max out the SPL.
Notice, with that offer, you're ONLY getting the speakers, NOT the reciever. If you don't already have a good HT reciever, you'll have to budget that in as well.
Scott -
I like the Synergy series. The sound response is flat through the full range. Seventy-five (85 maximum) watts per channel can fill a 24' x 18' room. They list at $350 new for a pair, but can be easily found for $150 used. You will need matching center ($150) and surrounds ($125). With good speakers like these and a fine receiver like the Yamaha HTR-6240, a sub-woofer for the bottom octave-and-a-half is optional. These bookshelf speakers weigh about eleven pounds each. You may need large ball-joint mounts to place these speakers where there is no shelf.
This is just an example auction. I would purchase only from an experienced dealer with a hundred speaker sale transactions.
Klipsch Synergy B3 bookshelf speakers
Last edited by luigi2000; 1st Sep 2010 at 22:27. Reason: the optional bottom octave and mounts
What kind of speaker system is hooked up to your computer?
By johns0 in forum PollsReplies: 29Last Post: 22nd Feb 2012, 04:33 -
Suggest to me: inexpensive 5.1 speaker system
By RogerTango in forum Media Center PC / MediaCentersReplies: 0Last Post: 23rd Oct 2011, 19:34 -
Need a speaker system for the TV
By beavereater in forum Off topicReplies: 2Last Post: 7th Sep 2011, 18:18 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 05:49 -
I want some suggestions for setting up a speaker system
By wan2no in forum AudioReplies: 4Last Post: 11th Aug 2007, 23:09
