Hello
I want to encrypt files Hidef (. Mkv) to DVD (. M2v) encoding with TMPGEnc 4.0 XPress.
(Or any other encoder is better able to guide).
If I want to use to help encode avisynth to the definition side near the original as possible.
Have you any advice on how to do some.
Sorry, I'm not good with the language.
Thank you.
Thanks for the suggestions.
I have some advice on encryption Hidef (. Mkv) to DVD (. M2v).
Currently I'm using TMPGEnc 4.0 XPress to encode which has the unpleasant
I want to consult with encryption software. Encoding of the program (. Mkv to. M2v).
The new results come out of that close to original as possible.
Thank you. -
It won't come close in quality no matter what you do . It will always be a lot worse. The limitation is DVD-video specification . If you want same quality, make an AVCHD disc (you can put it on DVD5 media, but you need a blu-ray player to play it back)
You can try other software like avs2dvd , which uses a different encoder hcenc , but again, the limitation is the low resolution and MPEG2 encoding. It will still look like garbage compared to original on a HDTV -
HC Encoder I try to encode and results are satisfactory. But I also do not adjust the fine if the various HC Encoder Options may be more clarity on this (I only encoded Video (No audio &
Subtitle)).
Any customization HC Encoder please recommend how to adjust for encryption .m2v (using avisynth, etc.).
Thank you very much.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
T2 HiDef Playback
By Megahurts in forum Software PlayingReplies: 23Last Post: 11th Sep 2010, 00:16 -
Convert a DVD to an avi,mkv using Avisynth Scripts and VDubMod or MeGUI
By ppeterr in forum DVD RippingReplies: 6Last Post: 25th Apr 2010, 06:04 -
Trouble with .mkv and VirtualDub using AVISynth
By Jonnycat in forum Video ConversionReplies: 3Last Post: 6th Apr 2010, 17:43 -
Transferring HiDef DVC tapes TO ANOTHER HI DEF MEDIUM HD DVD/BlueRay/Other
By LCC0256 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Oct 2008, 16:49
