Can you save a filter chain so every time you start Virtualdub you can load the same filters in the same order?
I'm capturing a lot of VHS tapes and want to use the resize, Dynamic Noise Reduction and DotcrawlComb filters on all of the tapes ( I think). I'm not sure if those are going to be the ones I use, I'm still learning about and experimenting with filters.
Also what's the best way to preview filters.
Does it make a difference what order you load the filters in?
Do you have to load them in the same order every time to get the same effect?
Thanks in advance.
Set you're filter chain in virtualdub, and go to "file/save processing settings" and save the settings file where ever you want, and when you need the same filters just load that file using "file/load processing settings".
And yes, the order of filters makes difference. -
Thanks everybody.
Being able to save a chain instead of having to make it from scratch every day helps a lot.
Apparently I've been using the filters in the wrong order.
I'll change that.
Graphedit filter chain with ac3 audio
By sambat in forum Video ConversionReplies: 3Last Post: 19th Jun 2011, 13:18 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 10:48 -
VirtualDub....save as .mp4
By Ogilvy in forum Video ConversionReplies: 2Last Post: 20th Mar 2010, 00:29 -
Can VirtualDub save DV-AVI's?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 21st Oct 2008, 10:10 -
Vdub Filter Chain
By christopheramos in forum Video ConversionReplies: 16Last Post: 3rd Sep 2007, 08:57
