A few days ago I submitted some DLT's to the mastering facility and they reported an error with the layer break. I think I found the error and reset the layer break, however, I called them to ask the size (in sectors) of the Layer 0 tape. All they were able to tell me was some of the data from the eclipse report:
End sector in layer 0: 2295BFH
Location Of Lead Out: 2295C0H
I suspect that the one labeled "End sector in layer 0" would represent the sector of the layer break. Problem is that I need it in decimal format (2,xxx,xxx sectors) to compare it to the layer break I have recalculated. How can I convert 2295BFH to decimal?
http://easycalculation.com/hex-converter.php
2295BFH = 2,266,559
Should I bonk you over the head now or later?
You must be tired. That was too easy.Want my help? Ask here! (not via PM!)
I'll take that bonk now, I didn't even think about finding a calculator online!!! Thanks, I can see that the layer break was way off now!
Yeah, I can do it on my ancient graphing calculator...
... but I did a quick Google hunt for "convert hex to decimal" and that was the first result.
http://www.google.com/#hl=en&source=hp&q=convert+hex+to+decimal
Wanted you to see it for yourself.
And have a handy tool in case you don't have a $100 calculator in a drawer like I do.Want my help? Ask here! (not via PM!)
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
Setting the layer break on a DVD9 (DVDLab Pro project)
By lorix in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2008, 11:19 -
How can I find out where a DVD9 layer break is timewise?
By sdsumike619 in forum Authoring (DVD)Replies: 5Last Post: 10th Nov 2008, 16:47 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 13:48 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
