Results 1 to 10 of 10
  1. PSCO2007
    May 2010
    Southern Ca.
    I converted an mp4 file to dvd and it plays fine on my computer.
    I used Dvdvideosoft-because avs to dvd kept freezing, and vso imprints a watermark).
    The completed file went from 1gb to 9gb and dvdshrink does not recognize it.
    This seems to be happening lately with all dvdvideosoft conversions.
    Is there any other program that would shrink this file to allow me to burn it to a dvd disc?
    Thanks for any advice.
    Did dvdvideosoft make a complete dvd with vob,ifo,bup files? Or just a mpg/vob file?
    And try other mp4 to dvd converters like dvd flick.
  3. PSCO2007
    May 2010
    Southern Ca.
    Baldrick,
    Thanks for quick reply.
    Dvdvideosoft did make full copy and normally dvdshrink does work.
    I tried dvdflick, which I have been using, but it kept freezing a 8%.
    I am now trying Xilisoft to create an iso image and then hope to dvdshrink will recognize that.
    Lower the video bitrate when you convert and you don't have to shrink.
  5. PSCO2007
    May 2010
    Southern Ca.
    Can you tell me how to do that?
    Thanks for all your help.
    Oct 2007
    Try FAVC to convert your MP4 into a DVD structure folder. Choose 4.37GB for the Disk capacity, no shrinking necessary.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I don't use xilisoft nor dvdvideosoft. But can't you specify andy video settings? Check for bitrate or in some tools can you set the output file size directly(like dvd flick, avstodvd).
    Maybe try FAVC and the old good free DivXtoDVD, https://www.videohelp.com/download/vsoDivxToDVD_setup_0.52.99.exe
  8. PSCO2007
    May 2010
    Southern Ca.
    Thanks again.
    I'll give your suggestions a try.
  9. Originally Posted by Psco2007 View Post
    just a personal advice, Scan any software from DVDVideoSoft at-least by more than two prominent AV Scanners or @ Virus Total before installing into your computer.
  10. PSCO2007
    May 2010
    Southern Ca.
    Hi Baldrick,
    I finally got Dvdvideosoft to work by following your suggestion.
    One other question: I also tried Any soft to convert and it works on my computer, but I picked Dvd Pal and Dvd Ntsc and they are not dvd compliant so I cannot burn to disc.
    What format would I use in this program?
    Thanks again for all your help!
