Hi I use Media Player Classic and render with Haali Renderer from the K-Lite codec pack to play video files, I've noticed that when I play a video that has a higher resolution than my monitor Haali will re size the video to a smaller resolution, is there any way to turn off this function so that the videos simply fill up as much of the screen as possible?
Hmmm. Works for me. You have to go to full screen -- Alt Enter. I'm using the Haali Render built into MPCHC.
Changing default video renderer
By deadgamer in forum Software PlayingReplies: 0Last Post: 3rd Jul 2010, 07:02 -
MOV (MJPEG) file - audio but not video in VMC (using Haali and ffdshow)
By enoesque73 in forum Video ConversionReplies: 5Last Post: 10th Jan 2010, 16:17 -
Overlay renderer is broken
By TheLazy1 in forum Software PlayingReplies: 4Last Post: 15th Oct 2009, 17:41 -
Does Zoomplayer has it's own subtitle renderer like MPC?
By natsume shin in forum SubtitleReplies: 5Last Post: 29th Oct 2008, 10:37 -
Setting Default DirectX Video Renderer
By Ace-Of-Spades in forum Software PlayingReplies: 3Last Post: 30th Nov 2007, 10:31
