Hi there,
I am wondering if I can create audio CD from VCD disk and listen to the sound only (i.e. convert from .DAT to tracks)
Thanks,
Localadm
Yes, just demultiplex the MPEG and decompress the .mp2 (.mpa) to wav and burn it as Audio-CD.
Thanks Truman. Would you tell me the software to perform the task? Pardon me the new player in the field.
Thanks in advance!
Localadm -
One way of doing it is as such:
1) Demultiplex the MPEG using TMPGEnc. (Simple Demultiplex is located under the File | MPEG Tools in the menubar)
2) Open the MPA file in Winamp and set Winamp's output to Disk Writer. (Select Options | Preferences | Disk Writer)
Although there are tools floating around that will convert MPA to WAV, I like using Winamp as you can apply EQ or use a plugin like DFX to improve/change the sound quality of the WAV file to your liking.
Good luck,- bewley
bewley's mp3PRO Rock
classic/metal/new rock streaming 24/7
Ziggy In Concert
david bowie unofficial discography
Create DVD Audio Patch?
By Spawn1985 in forum Authoring (DVD)Replies: 23Last Post: 3rd May 2010, 23:25 -
How to create multiple audio in a video?
By zboyz in forum AudioReplies: 8Last Post: 13th Mar 2010, 10:18 -
create dual audio dvd
By jin007 in forum Newbie / General discussionsReplies: 4Last Post: 9th Aug 2008, 17:38 -
How would I create an Audio DVD from my audio files from scratch???
By Hittz in forum AudioReplies: 6Last Post: 10th Jun 2007, 03:15 -
how to create VCD protection?
By C-W in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th May 2007, 12:00
