Someone has just told me that copying mp3's from hard disk to hard disk or form anything to anything! Will lose quality? I'm not sure if i believe this.
Is that true? That if i copy one mp3 to another desination, if i keep doing it, it will degrade the quality of the mp3?
I dont see how this is possible.
Pls lemme know.
Cheers.
Results 1 to 14 of 14
Nonsense. The copied file is an exact copy of the original. What happens when your bank copies your financial records from one computer to another? Do you expect the records to change? One of the main features of digital data is that it can be copied ad infinitum without any losses, unlike analog data.
No. You can't degrade an MP3 by copying/moving it around several times (as long as the hardware you're copying it to is okay), just as you can't degrade an MP3 by listening to it multiple times.
If cameras add ten pounds, why would people want to eat them? -
only with hardware malufunction : eg. the hard drive is corrupted , or a bad sector
But then it would be noticibly bad right? Like there would be big glitches in the audio stream such as those 'underwaterry' sounds?
do u know what i mean?
Am i correct there? -
But what about this article here:
Is this saying otherwise?
http://en.wikipedia.org/wiki/Lossy_data_compression#MP3
Or is that only about if u re-encode an mp3?
Do you think this statement is true: (taken from the above article)
"Lossy compression formats suffer from generation loss: repeatedly compressing and decompressing the file will cause it to progressively lose quality. This is in contrast with lossless data compression."
Cheers.Last edited by SE14man; 31st Aug 2010 at 04:28.
Moving it from one place to another on your computer AS A DATA FILE does not change anything. Burning your MP3 back to a playable AUDIO CD changes the MP3 to a WAV file. I doubt you will notice any quality difference going from MP3 back to WAV....but the "damage" (compression, quality degradation) has already been done when you created the MP3 files in the first place. You DO NOT get that back. Once the original file has been compressed to MP3...the original quality is gone forever.
I hear you..
So basically as long as i dont re encode the mp3 it will stay the same quality?
When they say compressing/decompressing do they mean re encoding to another bitrate or just re encoding to the same bitrate will loose quality?
They dont mean compressing as in zip/rar file compressing right?
If i were to fill up a DVD-R with mp3 files wirtten as 'DATA' and i copy the files back form that DVD-R (as data) to the PC then surely there would be no quality loss either? Even if i were to repeat the process 100 times there would be no quality loss right? It just seems a way of storing them that does.. But however burning a video as a video cd or an audio as an audio CD i can see that losing quality as it encodes them itself doesnt it?
But just burning as a DATA disc for videos/mp3s this wouldnt lose quality would it? Cos its just storing them surely? -
Thanks for clearing that up for me!
So compressing the same mp3 file as zip/rar 100 times will make no difference to the audio quality itself?
(Not that id do this im just finding out if rar/zip compression in the long run affects the sound quality of mp3 files?
Cheers.
Copying a large MP3 audio file to 2nd CD-R once 1st CD-R is at capacity
By keypoints1 in forum MediaReplies: 10Last Post: 20th May 2011, 23:44 -
Any tools for copying / reading bad quality discs?
By Locut0s in forum DVD RippingReplies: 2Last Post: 12th Nov 2010, 09:06 -
Need Quality Converting, Copying and Editing Software?
By BassJunkie in forum Video ConversionReplies: 24Last Post: 19th Jul 2009, 03:49 -
Removing menus without degradation
By multiplex in forum Newbie / General discussionsReplies: 7Last Post: 29th Sep 2008, 20:58 -
Letterbox to Anamorphic with as little quality degradation as possible?
By beatchef in forum Authoring (DVD)Replies: 16Last Post: 5th Feb 2008, 02:10
