Currently I have been broadcasting a channel off my Digital Cable box via TVU or Sopcast so I can watch the channel at work. It's working out pretty good but the quality of the Video is pretty low and everything I have done to improve just doesn't help. Current backend Encoder is either WME or Expression Encoder 4 Pro. Now the biggest issue here is I got the 4 Pro because they allow you to use H264 encoding problem is when using H264 Encoding it can only be pushing to a media streaming server not pushed as a live broadcast.
So what I'm looking for now is either another all in one solution, Encoder/Broadcaster or just a top quality Encoder that will then push to TVU Broadcaster so I can broadcast a higher quality channel.
Hardware
I860
8 GB Ram
ASUS Combo TV Card My Cinema-EHC3
Bandwidth Upstream 5 mb
Software
Windows Media Encoder
Those are the options I have used so far, I would really like to get a high quality Stream so watching it isn't painful on the eyes. It can be an all in one solution or multiple programs I really don't mind but any help would be greatly appreciated.
Results 1 to 1 of 1
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33 -
converting it to higher quality
By JTG in forum Video ConversionReplies: 6Last Post: 27th Apr 2009, 17:22 -
assistance with vlc stream
By lolwthm8s in forum Video Streaming DownloadingReplies: 9Last Post: 20th Jun 2008, 04:03 -
Is higher bit rate = better quality??
By imdaman in forum DVD RippingReplies: 5Last Post: 13th Sep 2007, 07:37
