I have a Sony HDV SR1 camera & wondered how & what wireless mics to use with it?
Does the SR1 have an external mic jacK?
What audio are you trying to capture with the wireless mic? Detail helps.
What is your budget?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I think so theres a plugin towards the front of the camera. I want to film hunts, I want to be able to hear what the individual says that is hunting. When your out in the field you have to be very quite so you can't talk very loud & I want to be able to pick it up.
I would like to stay under $500. & would like to be able to use it with a lot nicer camera in the future. I plan to buy a much nicer camera over the winter.
So you only want to mic the hunter for voice?
Do you need to talk back to him?
Is there more than one hunter that needs to be mic'd?
Will the new camcorder have 600 ohm XLR inputs?
Low end starting reference is the Azden WMS-PRO $139-150. It is VHF (not a problem in the woods). This 10+ year old design works well for voice but may have urban interference. I once used one at an auto show at Moscone in SF. The presenter's voice was picked up on the house PA. Every word was heard throughout the hall.
The pro versions are outside your price range so I'll search for a middle solution.
Remember high quality pro wireless equipment can be rented cheap. The main market is weddings.Last edited by edDV; 30th Aug 2010 at 20:02.
If poss. I would like a dual set for either 2 hunters or the camera guy & the hunter. I'm thinking something along the lines of a Z5U or in that similar type of quality. I'm sure by next year there are going to be other options to conceder. Thanks for looking into this with me, it is appreciated!
To do two two hunters you will need two separate mono systems plus a 2x mono to stereo adapter into the stereo mic jack. This puts pressure on your $500 budget.
Something like this but the specs aren't specific enough for me.
http://www.audiogear.com/cgi-bin/shopper.cgi?key=ADPT2MMFMSM&preadd=action
You would want two mono to stereo.Last edited by edDV; 30th Aug 2010 at 21:57.
Podcasting using 3 wireless lav mics?
By chrisshawyeah in forum AudioReplies: 0Last Post: 20th Dec 2011, 01:17 -
Camera is hunting
By zoobie in forum RestorationReplies: 2Last Post: 15th Dec 2010, 16:17 -
Can I use two stereo mics or do I need two mono mics for stero?
By Graham Archard in forum AudioReplies: 2Last Post: 17th Mar 2010, 23:08 -
2 Mics for the Canon HF200... How?
By juststarted in forum AudioReplies: 3Last Post: 25th Nov 2009, 15:23 -
hunting...hunting... can't find "how to" this conversion.
By madmocha in forum Video ConversionReplies: 7Last Post: 8th Sep 2007, 04:29
