Hello all, this is my first post on here because I've just recently started to get my feet wet in video editing. I'm currently putting together a video montage (all are .WMV files). My question is how do I capture only the audio from a particular video clip bc I want to overlay this audio on top of a different video. Is there an audio capturing software (preferably free) out there that I need to use or is this capability in my editing program. I'm using cyberlink's powerdirector 8. Thank you in advance!
powerdirector should demux the video when you put it on the timeline. then you could save-as or render to whatever format you want the audio in.
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 02:45 -
What about audio capture?
By Fryster in forum Capturing and VCRReplies: 3Last Post: 25th Dec 2009, 09:47 -
capture not getting audio
By bbxrider in forum Capturing and VCRReplies: 3Last Post: 7th Aug 2009, 13:00 -
Old PC and want to capture TV audio, etc.
By cantthinkofanickname in forum Capturing and VCRReplies: 1Last Post: 21st May 2008, 13:33 -
How to - Capture DVD 5.1 Audio - Coaxial vs. RCA Audio
By JBredensteiner in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2007, 12:46
