Hi , I got a mkv and i'm using avstodvd to hardcode my srt and convert to dvd, so I add the sub and it's muxed then i go edit title (subs) and tick hardcode and change font but i end up with the hardcoded and softcoded
i assume it's something with ffdshow or vobsu and avstodvd
I'm not very experienced with ffd or vobsub so can someone help stepbystep?
You can ask the man himself:
https://forum.videohelp.com/threads/277852-AVStoDVD-release-2-3-1-(July-2010)http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
@striker9
if you have checked the 'Title Edit'/'Subtitles'/'Hard Encoded' option on, then AVStoDVD will NOT add soft subs to your DVD. You can verify that directly in the project log file: if there is no SubtitleCreator step then soft subs cannot be there. Otherwise report here the log file.
Bye -
Sure ill send the log cause i dont tamper with it i just check hardsubs and font and i get the plain soft subs and the fonted ones a bit above em
hangon i'm encoding now it's taking long coz i cliped a sample of a vid and resynced subs cause i deleted log file but it looks like it's working
Okay When i hardcoded that worked but i cannot change font and when i like mux it (stndrd sub) the sub wont play
Hardcoded Subtitles
By Bruno AUgusto in forum EditingReplies: 4Last Post: 7th Apr 2012, 13:29 -
Changing font size/color for hardcoded subtitles
By JMantis in forum SubtitleReplies: 4Last Post: 6th Mar 2011, 19:34 -
MKV, subtitles are tiny. How to change font size?
By anarchyx34 in forum Video ConversionReplies: 1Last Post: 14th Apr 2009, 01:17 -
DivX Subtitles: can u change the font/transparency in the .SRT file?
By chin569 in forum Newbie / General discussionsReplies: 11Last Post: 7th Nov 2007, 10:26 -
Extracting hardcoded subtitles-does anything actually work?
By kpic in forum SubtitleReplies: 3Last Post: 2nd Jun 2007, 06:34
