Newbie here
I would like to extract clips from DVD and compile the clips into a new DVD, and do this without any re-encoding.
I used DVDFab decryptor to rip the DVD and MPG2Cut2 to extract the clips into mpg2 files. Both are free software and work well.
But how do I compile the mpg2 files into a new DVD? Years ago I had bought Ulead DVD Factory and Nero but both say that they can not process AC3 audio and Nero even insists on re-encoding the video.
Shouldn't the mpg2 files be already DVD compliant? If not then how do I make them so?
Any help to compile the mpg2s into a DVD would be highly appreciated. Thanks!![]()
Try GuiForDVDAuthor, DVDStyler or DVD Flick(in dvd flick be sure to select to not convert compliant mpg streams).
Bitrate calcultor for HDV to MPG2 DVD specs needed.
By beammeup in forum Video ConversionReplies: 6Last Post: 14th Sep 2011, 11:09 -
Backup DVD, BD (Lossless)?
By JCarnon in forum SVCD2DVD & VOB2MPGReplies: 18Last Post: 23rd Mar 2011, 01:54 -
Lossless editing of mpg2 .TS files with errors
By jd594 in forum DVB / IPTVReplies: 0Last Post: 10th Feb 2010, 10:04 -
Is Lossless DVD Authoring Possible?
By blazin-j in forum Newbie / General discussionsReplies: 6Last Post: 4th Nov 2008, 14:34 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
