I´ve been using bdrebuilder for a while and i just recently "discovered" the sweetness of deinterlace at 60fps...but, i had some problems trying to do it on a 1080i file. Bdrebuilder just encode up to the middle of the lenght of the file. Eg. if it's a 1 minute file just encode 30 seg...if it is a 2 minute file encode 1 minute and so on.
Im guessing that bdrebuilder is just "counting" the actual frames of the file not the doubled frames that yadif gave.
I know 1080p at 60fps it's not a bluray standard, but im reencoding to mkv and playing it with my pc (Phenom quadcore, 4 gb ram).
Anyway, i figured out a workaround to my problem but i wanna know if theres a way to do it easily...maybe adding some avs script in bdrebuilder options? (BTW i don't know anything about scripts and avs XD).
Thanks in advance!
As a quick test, try adding Bob() to the script and see if it encodes correctly. If that works you can use more sophisticated bob deinterlacers like Yadif(mode=1) or TempGaussMC_beta1mod(). You could also try reducing the frame size to 1280x720p60 which is supported by BD.
Thanks for your reply jagabo!. I dont need a BD standard output 'cause im playing it with my PC...and can handle it 1080p 60fps
I've read about avs, but sincerly, i don't understand anything, maybe i have a tough head XD...all i know is that bdrebuilder can use avs scripts.
Is there a very simple anti-dumb guide to avs scripts??
Thanks!
Problem with BDrebuilder
By tarzan54 in forum Blu-ray RippingReplies: 10Last Post: 20th Jan 2012, 20:45 -
VirtualDub Deinterlace Filter yadif vs blend
By kreg in forum Capturing and VCRReplies: 1Last Post: 22nd Jul 2011, 13:42 -
KMPlayer and FFDShow deinterlace - how to get "bob" effect working?
By ANOther1676 in forum Software PlayingReplies: 3Last Post: 18th Feb 2011, 08:47 -
BDrebuilder
By durkinjt in forum Blu-ray RippingReplies: 3Last Post: 11th Dec 2009, 22:58 -
what's the avisynth deinterlace alternative for ffdshow's ?
By cobalt in forum Newbie / General discussionsReplies: 12Last Post: 24th Sep 2009, 10:34
