Is there a tool available that simply analyzes an AVI or MPG and displays the peak audio levels? Most of the AVI files I work with use PCM/WAV audio and the MPEG2 files use MPEG audio.
If you have Avisynth, get the Soundout plugin.
Then use an AVS file like:
to load the file.Code:DirectShowSource("file.xyz") Soundout()
The Soundout panel will pop up.
Click "Analyze sound" and you will get a report like:
Code:Analyzed 100%. [Ch 0] Maximum:0.05dB. Average:-23.33dB. RMS:-17.67dB. ReplayGain:-4.19dB [Ch 1] Maximum:0.04dB. Average:-22.29dB. RMS:-16.32dB. ReplayGain:-5.78dB [All channels] Maximum:0.05dB. Average:-22.79dB. RMS:-16.95dB
Thank you, that works well. A little more work than I was hoping for, but it works
. And I'm not sure if you put the backslashes in just for the example, but I had to remove them for it to work.
Code:DirectShowSource("file.xyz") Soundout() -
No, it shouldn't have had backslashes. There was a glitch in the forum software that put them in (really).
Glad you worked it out.
I didn't think you would try it straight away, if ever; usually if I recommend a simple script people act as if I've asked them to try colonic irrigation.
But once you have installed it all it's fairly simple to do. (Avisynth, not the colonic.)Last edited by AlanHK; 30th Aug 2010 at 13:56.
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 20:48 -
Converting .MKV files with subs to DVD. Cant find a good tool.
By anarchyx34 in forum MacReplies: 15Last Post: 25th Jan 2012, 11:05 -
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 08:25 -
Does anyone know any tool to check if files 'mpeg-2' are faulty?
By sgbd in forum Video ConversionReplies: 8Last Post: 13th Sep 2010, 21:12 -
tool to view audio levels
By tb582 in forum MacReplies: 0Last Post: 2nd Feb 2010, 09:18
