    Aug 2010
    Australia
    I'm trying to work out a simple, cheap (free's good) way to convert various Xvid files to MPEG2-TS format, so I can store them on my Set Top Box hard drive. It is a rather generic box with a USB port to which I can record and playback.
    Some info from GSpot taken from a file the DVB recorded from TV to the USB drive, ie the output format I'm trying to create (it doesn't mean a lot to me but perhaps will help those offering advice)
    VIDEO_ASPECT_TYPE_PAL PAL
    VIDEO_BITRATE 4267
    VIDEO_CODEC_NAME MPEG-2
    VIDEO_CODEC_STATUS Codec(s) are Installed
    VIDEO_CODEC_TYPE MPEG2
    VIDEO_DAR 1.778
    VIDEO_DURATION 6:03.400
    VIDEO_FIELDS_PER_SEC 50.000
    VIDEO_FRAME_COUNT 9085
    VIDEO_FRAMES_PER_SEC 25.000
    VIDEO_H264
    VIDEO_MPEG2 MPEG-2
    VIDEO_MPEG2_3X2
    VIDEO_MPEG2_BFF
    VIDEO_MPEG2_I_L I/L
    VIDEO_MPEG2_PPF
    VIDEO_MPEG2_PROG
    VIDEO_MPEG2_TFF TFF
    VIDEO_MPEG4
    VIDEO_MPEG4_BVOP
    VIDEO_MPEG4_GMC
    VIDEO_MPEG4_NVOP
    VIDEO_MPEG4_QPEL
    VIDEO_PAR 1.422
    VIDEO_PICS_PER_SEC 25.000
    VIDEO_QF 0.412
    VIDEO_SAR 1.250
    VIDEO_SIZE_X 720
    VIDEO_SIZE_Y 576
    AUDIO_BITRATE 256
    AUDIO_BITRATE_TYPE CBR
    AUDIO_CHANNEL_COUNT 2
    AUDIO_CODEC MPEG-1 Layer 2
    AUDIO_CODEC_STATUS Codec(s) are Installed
    AUDIO_MPEG_STREAM_ID 0xc0
    AUDIO_MPEG_SUBSTREAM_ID
    AUDIO_SAMPLE_RATE 48000
    It seems hard to find a single piece of software that will do the conversion without going to commercial software, which I'd rather not do if I can avoid it.
    Any help greatly appreciated
    I don't think any single free software can convert directly to a ts with mpeg2. I would probably try hcenc (or a gui for it like HCbatchGUI ) to convert to mpeg2 and then make a ts with tsmuxer.
