I'm very new to Blu-ray and all its file structure. I have a BDMV folder. How do burn this folder using Nero or other tools? I like to avoid re-encoding all the .m2ts files if possible. My understanding is that if I re-encoding all the .m2ts files, I lose the original blur-ray menu and all its features and only get the video and audio only, correct? I may even lose the chapters too, correct?
Forget Nero, use Imgburn. (free)
Mode -> Build. Drag the folder to the compilation window, and if there is one, the CERTIFICATE folder as well. Enter a label name if you like. Burn it, ImgBurn will prompt you to use UDF 2.5, hit okay and away you go.
Good luck.
[EDIT] If the BDMV folder won't fit, there are programs (e.g. BDRB) that can fit it to BD 5/9/25. You can specify full disc or movie-only. So no, you don't have to lose menus. Chapters you keep either way, and subs too if you don't de-select them.Last edited by fritzi93; 29th Aug 2010 at 22:22.
Pull! Bang! Darn!
Create MKV from a BDMV folder?
By elcoyoteloco in forum Blu-ray RippingReplies: 17Last Post: 4th Feb 2018, 04:06 -
BDMV Folder from fullhd camcorder can not play with Blu-ray player.
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th May 2012, 04:57 -
How play BDMV folder
By djdust in forum Blu-ray RippingReplies: 3Last Post: 4th Jan 2012, 04:00 -
Bad Teacher not ripping on AnyDVD HD, no BDMV folder?
By dsewardj in forum Blu-ray RippingReplies: 1Last Post: 24th Oct 2011, 23:18 -
Unable to play BDMV folder .. :(
By ahmadka in forum Blu-ray RippingReplies: 1Last Post: 19th Jun 2011, 20:41
