I tried to open a wmv file in virtualdub but all i got to work was the video but no audio. It said I was missing a microsoft audio codec.
I used the fcchandler plugin to open the wmv file in virtualdub. I enabled wmv[libavcodec] in the VFW interface of FFDshow. I got the video but can't get the audio to work. It said I was missing the wmav1 audio.
Any ideas how I can fix this? Thanks.
	If it's wmaudio pro 10 (5.1 audio) , it won't work
 You can use mediainfo(view=>text) to identify the characteristics
 A workaround is to use avisynth to load it into vdub
 If it's the regular WM Audio (WMA v2) , you can install DivX WMA Audio
	It's version 1(wmav1).
 I can't get avisynth to open it either. I get an error saying DirectShowSource can't determine the Frame rate(fps). How do i input the fps parameter that into tha avs file?
 DirectShowSource("c:\locationto\video.mp4"). Where does the fps parameter go? It's 25fps.
 Here is the info from mediainfo
 Audio
 Format : WMA
 Format version : Version 1
 Codec ID : 160
 Codec ID/Info : Windows Media Audio
 Description of the codec : wmav1
 Duration : 1h 31mn
 Bit rate : 128 Kbps
 Channel(s) : 2 channels
 Sampling rate : 44.1 KHz
 Bit depth : 16 bits
 Stream size : 83.6 MiB (5%)
	I'm think that link includes a decoder for WMA V1 as well
 DirectShowSource("video.wmv", fps=25)
 or you can use another source filter like ffmpegsource2 (separate plugin for avisynth)
 http://code.google.com/p/ffmpegsource/
 FFMpegSource2("video.wmv", atrack=-1)
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
