  1. sup guys........I want to know how to make chapters for my vcds.....I've tried makin em with ulead dvd factory but whenever I clicked on a chapter....the chapter would run for like 5 xeconds then freeze so I gave that up..now I'm into it again and after watching a vcd that I bought from this illigal place and I saw how they made chapters it got me interested...I want to knowhow to make em..with the pictures and stuff.....does anybody have a program iwth a guide or somethin..or can someone post a message here which will teach me how to make chapters..and tell me wat program to use also....thx...I think it was a while back when I say a guy post up this awesome write up on how to make chapters.....I wasn't interested then but I am now....so can someone plz help me.......thx a lot.....
  2. There are now a whole host of proggies that can make S/VCD chapters.
    If you want to spend lots of money, VideoPack5 is pretty good.
    If you want to do it better and in freeware ( ), then use VCDImager +/- one of the GUIs (e.g., VCD Easy or TSCV).
    I believe that Sefy has a newbies guide somewhere on this site from start to end on making a VCD with chapters using VCD Easy.
    I create a guide on the theory and practice of authoring chapters on S/VCDs using VCDImager here:
    http://www.geocities.com/medinotes/vcd/chapters.html
    http://www.vcdimager.org/guides/chapters.html (mirror)
    If you are a beginner, I strongly suggest you read the above link to understand how VCDs work and what limitations there are. Then, unless you are really brave, try using one of the GUIs like TSCV or VCD Easy. Once you get comfortable with how it all works, try manually editing the XML yourself. Once you've got it worked out, you'll be amazed as the power and flexibility of doing so.
    Good luck.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Hmm, so those "How To" links that are to the left of the board actually have info that tells you "HowTo" do things related to VCD, SVCD, DVD, and that sort of thing?
    Cool! :D
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    Feb 2001
    Berlin, Germany
    Mirror_Image, unfortunately many people are too blind to see it. :D
  5. Yup, there is a Classical Guide which covers you from start to finish and it includes Chapters (but not subtitles!), and you can access it here:
    http://www.vcdhelp.com/dvdtovcd.htm
    I hope you will find it easy as possible, I keep updating text there so it will be easier to understand.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
