Results 1 to 20 of 20
  1. Hello Everyone!
    I just bought Sony KLV-32EX400 and saw its specifications, it says that it can play Photo (JPEG), Music (MP3), Video (MPEG1, MPEG2 TS & PS) via USB. Now my question is that is it mean that i can play .mp4 and .m2ts videos directly? Thanks!
    Regards,
  2. Maybe *.M2TS with MPEG 2 video in it, not with AVC/h.264. Probably nothing in *.MP4.
  3. Anybody who owns this T.V can help more on this i guess.
    Online manual says its USB can play :
    - MPEG-1
    – MPEG-2 (MPEG-1 Layer II audio codec only)
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    - MPEG-1
    Then the manual means what it says. It should also specify max resolution and bit rate.
    http://www.kiva.org/about
  5. Given the specs the OP posted, and the fact that it's Sony, I suspect the TV is limited to standard definition files.
    Jul 2007
    Denmark
    Why don't you just try it?
  7. T.V can play .vob . I figured it. Can someone related some other formats? In specs, its written that MPEG-1 PS and MPEG-2 TS are supported. .VOB is extended from MPEG Program Stream (PS).
  8. Member edDV's Avatar
    Mar 2004
    So it only plays standard def transport streams? A digital TV tuner will produce those as *.ts or *.m2t files.
    You can convert normal mpg to a transport stream with TSMuxer.
    You can also convert nearly anything to an MPeg2 VOB using standard DVD encoding techniques.
    You just need to experiment.
  9. What's about mk2tovob ? Does this conversion lose any quality?
  10. Member edDV's Avatar
    Mar 2004
    I've never used it.
  11. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Depends on what you mean with conversion.
    Transcoding, which is meant in most cases, always gives a quality loss (bitrate/res).
    Digital tuners also record & save content as *.trp files and most times they are cut into 1.5gb pieces...*.ifo and *.idx files are added too.
    The recordings are TS / transport Streams in disguise, mostly.
    You need to combine them, then (re)mux to ts, vob, whatever you want.
    *** Now that you have read me, do some other things. ***
  12. TsMuxer converts MKV blu-ray rips to MPEG-2 Transform Stream but it comes with two folders i.e; BDMV and Certificate. Don't know T.V usb will detect it.
  13. TsMuxer just re-multiplexes the video. Ie, it takes the video out of one container and puts it in another without changing the video otherwise. Like taking a VHS tape out of a paper envelope and putting it in a cardboard box -- what's on the tape is unchanged.
  14. I think best option is to burn movies to DVD-RW and watch it via my blu-ray player and then delete it.
  15. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Maybe usb stick, CD-RW or BD-RE or DVD-RAM also comes into play, whatever your standalone is capable of managing...
  16. Here are specs of my player : http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&stor...specifications
    Can anyone tell me that is it capable of playing dvd-rw because its said DVD-RW read compatibility. See in Video Features.
    Here:
  17. It looks like the player will read DVD-RW. But Blu-ray players usually aren't very flexible with their playback of video files -- accepting a very limited range of file types, frame sizes, etc.
  18. At least it will play .avi
  19. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    It says DVD-RW in VR and videomode, which sounds good.
    But, have inmind, a DVD-Rw isnot always a DVD-RW. I know it sounds weird, but using 2x DVD-RW is not entirely the same as a 6x DVD-RW.
