Hi, I have a dvd rip of Terminator 4 salvation (6.5 GB)Can anybody please advice me what video settings i should use to get a Original DVD Quality as much as possible? in staxrip if i check profile dvix plus & quality 21,audio ac3, will my conversion get expected result? any suggestions will be greatly appreciated.
Literally the exact same quality? You'll have to use lossless h.264 and your file will blow up to 10 times it current size.
Divx h.264 at Q21 will look pretty good and usually recuce the size to around 1/4 to 1/2 a DVD MPEG2 source. You will be able to see differences if you look at enlarged still frames. Q18 will look very good but give a bigger file.
how do i copy DVDRAM disks to a pc hard drive (retaining exact quality)
By mnbvc in forum DVD RippingReplies: 19Last Post: 23rd Sep 2015, 14:18 -
Which settings for StaxRip and DVD => mkv (x264) ?
By QUEENFAN in forum DVD RippingReplies: 1Last Post: 23rd Dec 2009, 12:34 -
Best settings for VHS Rips useing STAXRIP
By contactadam2002 in forum Video ConversionReplies: 3Last Post: 25th Jun 2009, 17:33 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40 -
StaxRip Guide-w-Templates for High Quality XviDs
By Trac in forum User guidesReplies: 0Last Post: 24th Jul 2007, 01:53
