    Jul 2004
    Italy
    Hi
    I used DVDshrink to make a copy of an original dvd for personal use
    the sw seems very good but the problem is that the file copied are put in a folder ( audio_TS and Video-TS) and now I am not able to burn
    I have ImgBurn and Convertxtodvd or should I use Nero?
    Thanks/Fabio
    Jun 2004
    Victoria, Australia
    ImgBurn - Build Mode - add the VIDEO_TS folder
    - or -
    in DVDShrink select ISO as output format when saving, and then use WRITE MODE in ImgBurn
    Jul 2004
    Italy
    THANK YOU
    I see only now that there is an option by default to encode and burn with dvddecrypter
    does it work well?
    Apr 2004
    Miskatonic U
    Click on DVD Shrink in one of the posts and you will be taken to the DVD shrink page in the Tools section, there you can find a link to a modified version of Shrink that uses Imgburn for burning.
    Or you can just burn the video_ts folder, as suggested previously.
    Read my blog here.
    Jul 2004
    Italy
    cannot find any modifies fw in the tools section: any link?
    thanks
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Here it isClick image for larger version
ID:	3297 If you click on DVD Shrink in your last post, it will take you there
    Read my blog here.
