I've recently been trying to back up my collection to my newest laptop however for some reason DVD Shrink is spitting out ISOs that won't appear in Windows Explorer or in my Roxio Media Creator program.
However, when I try to shrink the DVDs into ISOs, DVD Shrink insists the file already exists. ONLY when I click browse in DVD Shrink do the items appear, however, the ones that aren't appearing at all are shown with padlocks.
http://i36.tinypic.com/25s271f.jpg
In the image above, CARRIERS.ISO is the shrunk DVD that appears in Windows and Roxio but the others only appear when I browse through DVD Shrink.
Anyone know why this is happening?
	Always use AnyDVD (HD) in the background when opening a DVD. Then DVD Shrink can compress every DVD.
 If you like to create Image Files of your DVDs, then you need some tools:
 - AnyDVD (HD) to create *.iso and *.dvd files (A *.dvd file contains the Layer Break information of the DVD [2 layer opposite or parallel]
 - Imgburn to burn the *.dvd file to an DVD DL (Verbatim is very good) (Be careful, since 2.5.1.0 the ASK toolbar is in the installer (don't click to fast through the installation)
 - Virtual Clone Drive to mount your *.dvd files
 - Player like VLC media player, MPC HC (perhaps with ffdshow), PowerDVD or whatever you like ... test them
 I hope this helps you
	Nemesis556:
 I had that happen in Windows 7. It had been put in a virtual spot somewhere. I got it to stop that behavior by selecting where I wanted it saved instead allowing the program to choose. On WinXP DVDShrink always saved in the C:\ spot unless otherwise directed.
 Make a new folder that is the intended save place then direct the program to save to that folder and see if that makes everything nice again.
  How to get an "l"not an "I" when ripping the dvd subtitle to text formatBy cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50
  Ripping Blu-Ray to "Standard" DVD (not AVCHD)By cbstryker in forum Blu-ray RippingReplies: 2Last Post: 4th Feb 2010, 15:56
  What is "cyclical redundancy" in DVD Shrink?By jyeh74 in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 09:51
  Do they still have "invisible" surfing tools?By yoda313 in forum ComputerReplies: 3Last Post: 15th Oct 2008, 13:24
  is it safe to remove "analyze" files from DVD Shrink?By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2007, 15:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
