CS 3 Clip Management, Organization and Arrangement
Set-up: I currently have a project timeline open with 4 HDV clips that have already been edited to taste.
Goal: within the same project in addition to the "master", create/open a new sequence for each of those clips which will retain my edits.
Result: There will be a master sequence containing all 4 clips and 4 more sequences containing each clip separately.
End Game: That will/should allow me to import each of those clips individually into new projects as needed.
Please, how do I accomplish the above?
If I can find out how to clone a sequence by making another one exactly like the source, it could be placed (with a different sequence #) within the same project and manipulated from there which will work too.
A simple copy and paste doesn’t seem to work.
Thank you.
Copy and paste works alright.
In the master sequence using the selection tools together with the shift key select the clips in the timeline that you would like to copy to the new sequence, right click then copy. Then click the new sequence press ctrl+v to paste the copied clips, that's it! Do the same thing for the other 3 sequences.
Attn: HC Encoder Experts/Optimized Settings?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2011, 22:11 -
Calling all DVD Lab pro experts
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 18th Jul 2010, 04:56 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
