Hi,
I am new to ffmegX and am encoding Video_TS folders. Most of the Video_TS folders I have encode just fine, I use the standard settings on ffmpegX. Occasionally I get a movie that encodes in approximately 5 seconds and when I check it only the warning at the beginning of the movie shows.
How do I get the entire movie to encode?
Most DVDs have the main feature as Title 1 (VTS_01), but some DVD producer may have decided otherwise.
By default, ffmpegX encodes Title 1. This is indicated at the bottom right in the Video tab.
I expect your DVD has the main feature at a different title number.
Try setting a title number, then use the Play button. You should be able to recognize the right video in a couple of seconds. Quit mplayer using the 'Q' or 'Esc' key. Repeat as necessary for other title numbers.
ffmpegX Encodes Invalid Files
By 11clock in forum ffmpegX general discussionReplies: 4Last Post: 3rd Jun 2011, 11:31 -
No encodes working with ffmpegX
By mollycampbell in forum ffmpegX general discussionReplies: 21Last Post: 2nd Mar 2011, 00:27 -
encode a Keynote Quicktime movie to mpeg2 using ffmpegx possible?
By mkoehler in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2008, 10:16 -
I am creating a PPM format movie and want to display it w ffmpegX
By kesnermodoc in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2008, 17:00 -
Editing a Movie... Warning Box appears... What to do?
By UmmAddan in forum EditingReplies: 1Last Post: 21st Sep 2007, 14:00
