hi !
Since ten years, i have many videos on my hard drive and it takes many capacity. it is began very hard and long to backup my data so i need to reduce their size and keep the quality.
i wish to compress them into a codec which could keep the quality and compress really.
I don't care nor about the cpu ressources to play it, neither the compatibility with mobile players and other systems.
i wish only they stay playable in VLC and Adobe premiere.
so, which video codec compress more and keep more the quality ?
What format are your videos in now ? Depending on what you have, you may not be able to make them smaller without reducing quality, possibly substantially. Use mediainfo to determine what you have. Post a tree view here so we can see what you are dealing with.
Storage has become extremely cheap over the past two years, with 1 and 2 TB external drives being extremely affordable and great value for money. You are better off getting a couple of these and putting your video data there, than compressing it and reducing the quality.Read my blog here.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
How to maintain quality with avidemux? (which video codec?)
By tlee in forum Video ConversionReplies: 7Last Post: 7th Nov 2010, 08:39 -
I need to compress video to DVD but the quality is always lower...
By tzanaglio in forum Authoring (DVD)Replies: 6Last Post: 30th Apr 2009, 18:48 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
Codec Required part two update
By booyaka in forum DVD RippingReplies: 8Last Post: 15th Dec 2007, 00:25
