I am trying to start using AviSynth with Premiere CS4 on my Win 7 64 system. I am a rank beginner here so I thought AVSEdit would be a helpful tool but it won't install because it says it needs .Net 1.1 installed. .Net 3.5 is part of Win 7 so I'm guessing that AVSEdit 1.1.0.0 is not compatible with Win 7?
I installed an Adobe plugin; PremiereAVSPlugin-v1.95, I hope I can figure out how to use it. I used to use VirtualDubMod on my XP Pro system, which seems to work well with AviSynth, but I read somewhere that VirtualDubMod won't fly on a 64 bit system, so I'm trying to work only with AviSynth and Premiere CS4.
I've read all the "getting started" info regarding AviSynth, but if anyone has any info on what would be a good way to go, it would be genuinely appreciated.
May have been, but obsolete and unmaintained now.
Get AvsP.
Also long in the tooth (though I use it myself).
Use the latest VirtualDub unless you have a special need for the "mods". -
Thanks Alan-I'll check it out.
I'd love to get working with AVISynth, but like with most fresh starts using new software, the first part of the road can be a little rocky.
Thanks again for the advice.
Vobblanker works in Win 7 64 bit, 32 bit?
By redsandvb in forum Newbie / General discussionsReplies: 15Last Post: 15th Aug 2012, 15:12 -
what PVR win 7 (64 bit) software to use with this USB TV stick
By perfection in forum Capturing and VCRReplies: 6Last Post: 24th Nov 2011, 23:58 -
Win 64 bit - Quicktime - Adobe 64 bit
By beavereater in forum ComputerReplies: 1Last Post: 7th Nov 2011, 09:18 -
xvid4psp or XMedia Recode crash 1/2 way or 3/4 to complete in Win 7 64 bit
By pectin232 in forum Video ConversionReplies: 2Last Post: 3rd Dec 2010, 00:25 -
XVD4PSP 5.0-6.0 encoding for HD movies terribly slow on Win 7 64 Bit with..
By pectin232 in forum Video ConversionReplies: 2Last Post: 25th Nov 2010, 21:28
