After splitting an MKV , VLC reconizes the subtitles , but when I put a file on my FAT32 the blue Ray player doesn't reconize it.
Can anybody tell me what I do wrong or is a issue with the BD player ?
Thanks in advance
Hermannus![]()
Try splitmkv. Or are you already using it? then try mkvtoolnix / mkvmergegui.
If the MKV is from a Bluray than your player would not recognise the PGS/sup subtitle. VLC is one of the few programs that will play PGS/sup subtitles in a MKV. If that is the case you would have to convert the sups to srt. A MKV will play external srts if they have the same name as the MKV. You could give that a try.
Tony
What is the best way to split mkv files?
By Han Solo1 in forum Newbie / General discussionsReplies: 13Last Post: 24th Oct 2012, 23:01 -
Split a mkv container
By kyrcy in forum EditingReplies: 1Last Post: 9th Nov 2011, 17:40 -
Problem with split mkv
By nname in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th May 2011, 09:48 -
Split *.m2ts to mkv
By Emil007 in forum Video ConversionReplies: 11Last Post: 18th May 2010, 11:18 -
How do I split .mkv file to two parts?
By dilanalex in forum EditingReplies: 1Last Post: 8th Apr 2009, 04:08
