I do not know whether the mpeg-2 transport stream is the HD or SD video. Is the mpeg-2 transport stream = .m2ts = .mts = HD video or the mpeg-2 transport stream is just SD video?
As said an MPeg2 transport stream container can hold SD or HD resolutions. The codec within the packetized transport stream can be MPeg2, h.264 or other.
MPeg2 or h.264 codecs can be SD or HD, interlace or progressive.
Some common consumer level transport streams:
TOD - SD MPeg2
HDV/XDCAM - HD MPeg2
AVCHD - HD h.264
ATSC/DVB broadcast - MPeg2 SD or HD (DVB can be h.264)
TS/MTS/M2T are common continous transport stream extensions used for broadcasting or linear recording to tape or file.
M2TS is a random access version of a transport stream intended for flash media, hard drive or Blu-Ray players. M2TS codecs can be MPeg2, h.264 or other.Last edited by edDV; 27th Aug 2010 at 13:48.
http://www.kiva.org/about
Converting H.264 RTP Video to MPEG-2 Transport Stream
By trekgeek in forum Video ConversionReplies: 0Last Post: 20th Feb 2011, 10:24 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
Panasonic HD Video Camera - .MTS file vs. MPEG-2 transport stream
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 10th Aug 2010, 23:04 -
MPEG-2 transport stream... how to mux audio/video?
By Navstar in forum ffmpegX general discussionReplies: 1Last Post: 19th Feb 2010, 18:22 -
MPEG-2 Transport Stream ...
By DeathStalker77 in forum DVB / IPTVReplies: 3Last Post: 26th Feb 2008, 23:22
