Hi,
I have a MP4 video file (1.5 GB without subs) encoded as X.264.
I have the .SRT file for the movie which I have converted to .SSA format using my choice of fonts etc.
Goal: I wish to convert this MP4 video to AVI (encoded as xviD) with subtitles burned into the AVI.
First Approach (with VirtualDub)
I tried to do this using VirtualDub 1.9.9. This is how:
Loaded MP4 video file.
Video --> Full Processing.
Video --> Compression --> XvID. 1st pass. Save as AVI. (job control)
Video --> Filters. Loaded Subtitler by Avery Lee. Added my .ssa file.
Video --> Compression --> XvID. 2st pass. Save as AVI. (job control)
Started Jobs
Result:
One huge 6.5 GB AVI file (from 2nd pass output) with subtitles burned in.
One huge 5 GB AVI unplayable file from first pass output (later discarded).
Obviously, the file sizes are atrociously large to be written on standard 4.3 GB DVD discs.
2nd Approach (using Avidemux 2.5.3)
Loaded MP4 video.
Video Codec ---> XviD ASF
Configured for 2 pass and constant video size ~ 1500 MB
Filters --> Subtitles --> Added my .SSA file.
Audio Coded --> MP3 (Lame)
Stereo 160 CBR
Save Video as AVI.
Result:
One 1.6 GB AVI file with subtitles burned in but they appear only for first 5 to 6 minutes after which there are no subtitles in the rest of the movie.
My Question: Is my method right? When I hard sub a XvID AVI to XviD AVI using VirtualDub, there is no issue. This time the source is X.264 MP4 which is causing issues.
Should I first convert the MP4 to a XvID using VirtualDub (first step) and then burn the ssa subtitles into the just converted XvID file as a second step? This will take a long long time though.
Please advise.
Thanks in advance,
S Ray
	The source video shouldn't really matter that much but it seems to do so here...
 Have you tried do one pass encoding virtualdub? Do a short encoding and see how it work.
	Single pass created a 12 GB file !!!!!
 (It seems VirtualDub is not honoring the size limits set).
 I will check with a different srt file.
	Virtualdub in Full video Processing may generate large file.
 with vobsub/vsfilter plugin might be able to hard-sub .srt to avi.
	This should work easily in Quick AVI Creator. Just use the TextSub function to burn in the subs. Or you can demux yourself and use xvid_encraw with an .avs file as input with the same TextSub function. Quick AVI Creator uses virtualdubmod to demux. For xvid it has 2 types of 2 pass mode. But I just added my own "one pass mode" by adding this to the xvid.presets file:
 [One Pass Mode]
 xvid_encraw.exe -i "$video_input" -bitrate $video_bitrate -progress 2000 -avi "$video_output"
 It's sort of like an .ini file. Whatever is in the brackets will show up in the drop down menu when you select "encode the video" after AvsP lets you edit the AviSynth script to add your filters(TextSub())http://milesaheadsoftware.org/
 Fully enabled freeware for Windows PCs.
  How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACTBy lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 15:04
  Need DVD Rip Step-By-Step Instructions For Best QualityBy bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 10:28
  mp4 (h.264) Demuxing: Is it possible to save a step when encoding to ac3By Krelmaneck in forum Newbie / General discussionsReplies: 4Last Post: 28th Jan 2010, 07:04
  The Complete Step By Step DVD Ripping/Burning Primer for Mac...?By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 08:04
  Audacity guide for beginners, step-by-stepBy AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 21:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
