Hi everyone!
I'm a noob when it comes to MKV files. I have recently downloaded some mkv files with subtitles embedded in the video but then it's not hardsubbed (hard concept for me to grasp).
My question is, does convertxtodvd able to convert these mkv files with softsubs into DVD like a regular avi file?
Thanks!
Yes. ConvertXtoDVD will (generally - no guarantees come with anything any more) read the subs form an MKV and create a soft subbed DVD for you. When you load the MKV file you should see the sub streams listed in the details.
Read my blog here.
Gunslinger, I do see the subtitle stream. My next problem is when I finished a "test" dvd, the subtitles go off the screen. How do I fix that?
You can edit the subtitle font, size and placement in ConvertXtoDVD
The problem is the overscan area of your TV, vs the placement and size of the subs. You need to use a smaller font to make suer the edges don't fall into your TV's overscan area. You may also have to lift the subs higher up the screen if they are falling below the visible area.Read my blog here.
it doesn't seem to do well with AVCHD files though... which is too bad because I like using it.
Canon VIXIA HG21 || Vegas Pro 9 || Digital Juice || Photoshop CS4 || 2.33 GHz Intel Core2 Quad Q8200 || Windows 7 Pro || 4 Gb Kingston RAM
Burning avi/mkv/whatever files as a BD-R/RE data disk for my Blu-Ray player
By Braindrain in forum Authoring (Blu-ray)Replies: 8Last Post: 25th Jul 2014, 08:13 -
Burning MKV Files
By PHNeedsHelp in forum Authoring (Blu-ray)Replies: 1Last Post: 7th Mar 2012, 10:59 -
Burning some WMV and MKV files to play on a DVD Player
By marnisper in forum Newbie / General discussionsReplies: 4Last Post: 7th Oct 2011, 09:24 -
New MKV File-convertxtodvd won't convert it.
By jbitakis in forum Video ConversionReplies: 17Last Post: 4th Feb 2009, 15:51 -
.avi/.mkv to dvd - faster than convertxtodvd?
By aod2002 in forum Video ConversionReplies: 0Last Post: 11th Jan 2009, 19:31
