I'm looking to capture some old SVHS tapes using uncompressed avi or with a lossless codec/
When using the passthrough of the Panasonic DMR-ES10 , would the output be MPEG2 encoded? or would it be a passed through output with just the TBC applied etc.
The DMR-ES10 only has analog AV connections, so MPEG-2 isn't even remotely possible. It provides a filtered analog signal as a pass-through.
I think the question means (forgive me if I'm wrong): Is the digital video with timebase correction converted back to analogue before the MPEG2 compression stage or after? If it's after then the analogue signal at the ES10's output would have MPEG compression artifacts mixed in with it.
The passthough signal has no MPEG compression artifacts, just time base correction (it may also adjust levels a bit too -- at least the ES15 does -- https://forum.videohelp.com/topic368189.html#1969469). If you record onto DVD and playback it will have MPEG artifacts, of course.
Panasonic DMR es10 working question
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2012, 18:02 -
No video displaying Panasonic DMR-ES10
By nocutename in forum DVD & Blu-ray RecordersReplies: 2Last Post: 22nd Jul 2010, 06:47 -
Panasonic DMR-ES10 - Audio Quality?
By Kryzon in forum DVD & Blu-ray RecordersReplies: 10Last Post: 29th Dec 2009, 19:17 -
Panasonic DMR-ES10 No recording
By TAMMU in forum DVD & Blu-ray RecordersReplies: 12Last Post: 22nd May 2008, 22:52 -
Panasonic DMR-ES10 Reviewed
By zorankarapancev in forum DVD & Blu-ray RecordersReplies: 42Last Post: 1st Apr 2008, 21:45
