The three times I ever used my Aiptek A-HD+ 1080p camcorder to record something on the big 57" Sony HDTV, the volume on the TV was loud and clear, however the video that was being streamed to the camcorder as well as the .mov my camcorder outputted both had an extremely low volume; why didn't it record the same volume level as the TV had? Could it be because the TV uses surround sound, and it created the illusion of a loud volume, but in actuality it was low? Also, how can I fix the .mov file so that its audio is at a decent level? If it helps, I recorded by hooking my camcorder up to my cable box and it acted as a capture card. No, I do not plan on disseminating the content I recorded; I did it so my step-father could watch it since he is at work, kinda like using the DVR or whatever to record shows you miss.
Results 1 to 1 of 1
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 05:57 -
Converted mkv has extremely slow audio
By PandaShake in forum Video ConversionReplies: 5Last Post: 4th Jul 2009, 04:15 -
Extremely low burn speeds, High CPU usage
By BetaMaster in forum Authoring (DVD)Replies: 13Last Post: 20th Nov 2008, 13:23 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 19:04
