Hi. I have a widescreen video clip that is a 4x3 stretched out to 16x9. I want it to be in it's normal stage (4x3) and I have searched after guides but almost everything is 4x3 to 16x9 and the rest is 16x9 to 4x3 with black borders. To convert video I use AVStoDVD because it is simple and works for my conversion. The problem is that then I choose 4x3 it add black borders. Is it my eyes or my search words because their must exist guides and tools to shrink a widescreen to fullscreen without black borders. VLC support it in real time. Thanks...
	Just change the headers to 4:3 with dvdpatcher or for avi mpeg4 modifier.
 Or reconvert and resize to a 4:3 size like 640x480 with a video converter, like avidemux or xmedia recode.
 If you want more details then give us more details about your source file.
	The source is .flv but I'm converting it to mpeg to work with it. DVDpatcher seems to be the best tool for this operation. Thanks...
	Just do the resize, but turn OFF the option for "Keep Aspect Ratio" (if there is one!)
  Converting 16x9 video to 4x3 letterboxed in Sorenson SqueezeBy pjbarbour in forum Video ConversionReplies: 0Last Post: 10th Mar 2010, 10:49
  Stretch 4x3 menu to 16x9By kpic in forum Authoring (DVD)Replies: 10Last Post: 31st Jan 2010, 13:45
  42 inch plasma widescreen (16x9 hdtv has native resolution 1024 x 768 (4x3)By sbt5 in forum DVB / IPTVReplies: 15Last Post: 4th Aug 2009, 22:59
  4X3 capture to 16X9 export? (minidv)By bufalo in forum Authoring (DVD)Replies: 12Last Post: 13th Jun 2008, 02:07
  DVD converting 16X9 to 4X3 letterboxBy DVDBear in forum Newbie / General discussionsReplies: 3Last Post: 26th Jun 2007, 05:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
