As I am burning my SVCD I have some associated files like images, text info and others. I would like to burn them as part of theSVCD.
Is it possible to add a data folder to the SVCD layout and burn it and still have it play corectly on all DVD players?
thanks
I'm assuming you're using Nero to burn. I do it every time in the VCD creation, so I'm assuming you can in the SVCD. Simply right click in the window next to your CD root layout (the far top left window) and choose to CREATE FOLDER (I name my JPG), then simply drag and drop the contents into it. This is a very good way to keep any menu photos, or cover art with the movie, so if you ever need it again it's there, or if you make people a copy, they can grab it out of there very easily without troubling you over it.
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Yes, I use to do this to save template, scripts and something like that.
I use VCDImager (with TSCV) and CDRwin. -
Thanks for the reply.
Wouls I just create another folder in the oot directory of the SVCD?
DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
By SetoTitan in forum SubtitleReplies: 9Last Post: 6th Jan 2018, 06:30 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
How to safely add user data folder to DVD Video?
By fvisagie in forum Authoring (DVD)Replies: 3Last Post: 1st Oct 2008, 06:32 -
Burning VIDEO_TS folder to a DVD disc as Video not Data
By xtaint in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 08:23 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48
