I'm running the 64 bit version of Sony Vegas Pro 9.0e and installed a Mike Crash noise filter, it installed itself here: C:\Program Files (x86)\Sony\Filters\, but it will not show up in the Vegas filters list. I tried installing it in other Sony Vegas directories with no success. I installed and used this filter before, but then I was running the 32 bit version. Is this an issue with the 64 bit version? Is there another folder I need to install it to make it work?
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 12:55 -
Vegas Pro 8 project won't open...
By montageman in forum EditingReplies: 4Last Post: 30th Nov 2009, 06:56 -
Filter Rendering Workflow in Vegas Pro 8
By SCDVD in forum EditingReplies: 3Last Post: 31st Dec 2008, 20:37 -
Mercalli Stabilizer Plug-in for Sony Vegas Pro 8
By SCDVD in forum EditingReplies: 3Last Post: 16th Dec 2008, 23:39 -
Skin effect plug-in Vegas Pro?
By jnaizer in forum EditingReplies: 1Last Post: 16th Dec 2008, 18:39
