Been discussing this with Woopra via Twitter, but thought I'd post the whole story to the forums anyway.
I was using the Woopra WordPress plugin to track my stats, but it stopped working. So I followed the instructions
to set up the tracking manually. When I tried logging into the desktop client, however, I got the message "Unable
to connect to Woopra".
I checked my username & password by logging into Woopra.com, and could log in fine. The tracking script logs my
visitors, because I can see them from here.
I've disabled my firewall (basic Windows firewall) even though Woopra has been excluded from being blocked & that
did not change the error message of "unable to connect".
I've tried uninstalling & reinstalling the software. No change. I could find no other troubleshooting tips.
Kiara
Woopra sucks
Woopra ripoff
Woopra garbage
Woopra infected with virus
Woopra stole my credit card data
Woopra trojan virus
Woopra spyware
Woopra malware
Woopra got my girlfriend pregnant
I'm a psycho....I mean psychic.
Woopra is actually really good tracking software for websites.
@hech, I think you're definitely psycho on this one.
@ connorabb, your location may have something to do with the connection issues. Beyond that, however, I have a feeling you're experiencing a larger computer issue and not one of the software.Want my help? Ask here! (not via PM!)
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
connorabb-Please do not post spam links again.
While this plugin may be passed via the firewall you may need to specify individual TCP and UDP ports for the plugin as well
Ie
Name > Woopra.udp
Port >11228
Check > UDP
Name > Woopra.tcp
Port > 11228
Check > TCP
Ok > Ok
Try again
Depending on how you connect to the internet you may need to setup ports again ... ie > dsl modem (open required ports) ... refer to what is known as "port forwarding"
Client not paying....question!
By dmdobsonjr in forum Newbie / General discussionsReplies: 13Last Post: 9th Jun 2010, 17:05 -
How to change the desktop grid size in winxp
By mysts in forum ComputerReplies: 3Last Post: 12th Sep 2009, 21:16 -
Free FTP client
By zoobie in forum ComputerReplies: 2Last Post: 1st Apr 2009, 02:49 -
Need to customize desktop icon appearance in WinXP
By alegator in forum ComputerReplies: 3Last Post: 12th Jun 2008, 13:30 -
remote desktop client
By Tom in HD in forum MacReplies: 2Last Post: 10th Dec 2007, 16:17
