One day I burnt out an AVCHD disc. On my PS3 the video on that disc plays back smoothly, no any flaws at all. On my friend's regular BD player (Samsung) the same disc plays back with some flaw (skipping, video hangs on). So I thought it could be a defective disc and (just out of my curiosity) I burnt the same video out on another blank DVD disc. To my amazement the same flaw had appeared at the same spot/time on the disc as it were playing on my friend's BD player. Amazing !!! Despiting a common sense I have bought another pack DVD's and burnt the same video again. Checked on my friend's BD player and... same problem at about the same time of playing back of the AVCHD disc. That's weird and interestingWhy
				Results 1 to 11 of 11
	Not all players support AVCHD, and those that do don't all support it equally. There are restrictions on how a disc may be authored, what bitrates and encoding parameters may be used etc. Bottom line : there is no way to guarantee that the same disc will play happily on all AVCHD compatible systems. Something in the way you have encoded or authored your AVCHD disc doesn't agree with the Samsung. This is one of the reasons MultiAVCHD has so many possible output options. Read my blog here.
	Recently I've put this AVCHD disc to play in my PS3 and push the >select< button to see the bitrate rate. About the time when video gets the problem on Samsung BD player I see very high bitrate (the highest I've seen there is up to 31Mbps). Comparing to the rest of video/timing where it plays back smoothly I can say it is extremely high bitrate.
 Could it be the matter ? Very high bitrate in comparison with the rest of the video which plays smoothly ?
	That would do it. I have no idea how you created this disc or encoded the material, but I suspect that Samsung has a much lower threshold for bitrate than the PS3. The solution will be to re-encode at a lower average bitrate using an encoder that has better control over spikes. Read my blog here.
	Thanks again for the answer
 Okey. Maybe do you know about which program/encoder would be good for this
	What was the source ? Was it already AVCHD compliant, or did you have to re-encode it ?
 The other tool I have used successfully is AVCHDCoder. It is simpler to use if you don't need the menus and more advanced functions that MultiAVCHD provides.Read my blog here.
	The original AVCHD 1440x1080i h.264 camcorder format was 16 Mb/s CBR, later expanded to 1920x1080i 24 Mb/s CBR. The HDV MPeg2 25 Mb/s CBR format also usually works in the AVCHD file structure.
 Players vary but these are the formats they are targeting. Keep in mind that the higher the bit rate, the faster the DVDR disc must spin. Extreme VBR may cause a buffer overflow.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I had a similar problem when I started making AVCHD discs, tried everything and nothing fixed it. Then OPPO did a firmaware update on my player and everything has worked great since. This could be your problem. Samsung may need to tweek firmware.
  date/time stamp on AVCHD possible?By Mike82 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 26Last Post: 17th Aug 2014, 18:26
  AVCHD Disc or Blu-ray Disc?By p_l in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Jun 2011, 20:56
  AVCHD PAFF Deinterlace / Video time length problemBy tat2jr1 in forum Video ConversionReplies: 4Last Post: 24th Jul 2009, 04:58
  Steps to convert BDMV to AVCHD: data disc problem with PS3By devilcoelhodog in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Jan 2009, 19:53
  Time Lapse help, mpeg2 from AVCHDBy cjbrown80 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 09:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
