MPEG2-TS
AC-3 5.1
Compression mode 4:2:0
Resolution: 1920x1080i @ 29.97 fps
GOP configuration 15 frames in size with 2B frames between reference frames
Black level 0 IRE
PCR refresh rate 37ms accuracy 5ppm
PMT 480, PCR & Video PID 481 and Audio PID 382
I am using TMPGEnc 4.0 Xpress. When I chose MPEG2-TS I don't get an option of AC-3 Audio. I get the option of Dolby Digital, but when I try to encode the file it says that it is not supported. Additionally I don't get any options for PMT, PCR, Video & Audio PID.
Do I need additional software, or is there a standalone software that can replace TMPEGEnc.
dolby digital=ac3.
You could use hcencoder to just convert the video and separate encoder for ac3 like aften. Then make a ts with tsmuxer. But I guess you are looking for all-in-one solution, maybe mainconcept reference, cinema craft encoder....kinda expensive though. -
You might try installing AC3 ACM Decompressor and see if that helps. If you need a bit more complex authoring program, maybe GUI for dvdauthor
I was able to create a separate dolby digital audio file so I can mux it back through tsmuxer. However, I am still at loss for configuring the minute details like
The resolution of 1920x1080i ... should i use interlace, I was using progressive.Compression mode 4:2:0
Black level 0 IRE
I don't get any settings to set the PMT, PCR and Video & Audio PID... any software to configure those?Last edited by vid2me; 26th Aug 2010 at 15:46.
Is there any software recommend to handle TS in the following way?
By ihmcjacky in forum Video ConversionReplies: 11Last Post: 2nd Dec 2010, 13:29 -
can you recommend good ripping software ?
By Bansaw in forum DVD RippingReplies: 2Last Post: 14th Sep 2010, 18:39 -
Can anyone recommend a freeware screenwriting software?
By rijir2001 in forum Off topicReplies: 0Last Post: 25th Nov 2009, 23:44 -
Please recommend software
By ccm2 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2008, 11:23 -
Recommend burning software other than Nero
By majax79 in forum Newbie / General discussionsReplies: 23Last Post: 30th Oct 2007, 15:30
