    Oct 2008
    HI
    I did not realize that EasyCA USB 2.0 Video and Audio Capture needed a name & registration number when installing software, where would you find name & registration code?
    Feb 2004
    Australia
    Serial should be on the cd sleeve on the back ... name could be anything you want to use
    Oct 2008
    Nov 2010
    Kingsport TN 37664
    I just bought EasyCap USB 2.0 video capture and I find no registration code anywhere on any of the materials that came in my order. The CD envelope is perfectly clear front and back. Any other ideas?
    Aug 2006
    If there is nothing helpful in the paper documents included with your order, all I can suggest is to look for a readme file on the CD or instructions on the seller's/manufacturer's website, or contact the seller/manufacturer for instructions.
    Every few days there is a new post here about some problem with an EasyCap USB 2.0. The EasyCap USB devices sold for next to nothing on ebay and other websites are only a good deal for some buyers and a headache for the rest.
