  1. Hi all. Usually, I can take an SVCD image or CD and copy the MPG file out of the directory structure, then do whatever I want to it.
    However, I have several MPG2s that play fine in PowerDVD, but won't open in VCDImager (using GUI) or in TMPGEnc... Any ideas?
    In PowerDVD if I turn on info, looks like it's variable bitrate, and audio is 224...
    Thanks!
  2. I also downloaded an episode of Smallville that has the same problem - if anyone wants to have a look at my problem, I could send them a 5MB or so clip from it...
    try (re)multiplex the mpg with svcd settings
    www.vcdhelp.com/bbmpegedit.htm
    (it wont affect the quality)
    and you should be able to open it in vcdimager.
  4. Cool, I'll try that, thanks! :)
  5. Worked like a charm! Thanks again for the help!!!
