In the pursuit of a personal project to capture and clean-up an old video I have purchased an ATI Theater 650 Pro card.
The tuner on the card works fine using WMC or SageTV, but when I try to capture with the VCR or TBC plugged into the S-Video jack (there is no composite jack) I get the video for a few moments and then I get heavy snow with the 'ghost' of the video moving under it. After some time the video may fade back in but then quickly out again and so forth.
The card is 1x pci-e and is in the correct slot on the motherboard.
The results are the same regardless of what program I use for capturing; primarily VirtualDub and Virtual VCR but also with SageTv I have the same results. Captured file is same as preview.
I have used 2 different VCRs, they play fine to the TV and there is no issue capturing using a Hauppauge HVR-1950, so it seems to be the ATI card. I've had it for a few weeks now but I think I can try to exchange it, however I want to see if it might be something on my end first.
Any insights?
--dES
"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Thanks for the response Jagabo.
That makes sense and I have to admit I did not consciously think about the Macrovision. I thought I put the TBC inline at some point but now I can't remember if I did or not.
I will make certain to do that when I get home tonight and see what happens.
Thank you!
--dES"You can observe a lot by watching." - Yogi Bera
Well, putting the TBC inline solved the issue.
Can't believe I forgot about the Macrovision
I should stop trying to do these projects at 2am.
Thanks again.
I have the AVT-8710.
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 13:41 -
Capturing TV Broadcasting using ATI TV WONDER 650 PCI
By jluke in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2009, 01:10 -
Widescreen Output Using ATI Theater 650 Pro and Ulead VideoStudio X2
By waldodiodio in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 11:00 -
Sapphire Theater 650 Pro Only Gets NTSC
By drstew in forum Media Center PC / MediaCentersReplies: 0Last Post: 12th Jan 2008, 16:34 -
which is better Dell 2407WFP-HC component input or ati 650 pro
By garyk in forum Media Center PC / MediaCentersReplies: 6Last Post: 11th Sep 2007, 04:12
