This is exactly what i have been seeing!, sometimes its really good saving, sometimes its awful, and when i modify smal changes with the bitrate it seems to dramatically change whether its good or awful with no predictable results.
Small changes to 5-6 may be ok, as long as they are small! the bit for bit differencing will cope with that at a cost of describing those frames which have changed is small (if its large, then its competing with jpg compression again).
It sounds like whatever i do with this, it wont be scientific. There is an added disaster that the sequence of images at the start could be just 1 image or many hundreds of images long over time, which would make the bitrate calculation difficult (maybe impossible - ive not solved it yet), as a default bitrate would need to be defined and not changed from patch to patch.
Thanks, i appreciate your help, and your clarifications, alot of what you have described, im seeing and now i understand a bit better why.
I'll try the intra suggestion and post my findings.
Results 31 to 31 of 31
A strange security scenario...
By davexnet in forum ComputerReplies: 7Last Post: 9th Feb 2012, 20:06 -
Unusual Scenario for DV capturing of Self Recorded VHS
By jcpost62 in forum Capturing and VCRReplies: 7Last Post: 15th May 2009, 12:29 -
Sobering Cyberwar Scenario on NPR today- Pearl Harbor II
By ahhaa in forum ComputerReplies: 2Last Post: 27th Jun 2008, 21:18 -
which scenario gives a higher quality video?
By graysky in forum DVD RippingReplies: 19Last Post: 3rd Sep 2007, 11:40 -
Bizarre VERY Slow AVI Render Scenario
By maxtrack in forum Newbie / General discussionsReplies: 15Last Post: 6th Aug 2007, 18:18
